Does someone knows how to bridge this amplifier ??http://www.construyasuvideorockola.com/downloads/amp200wHD.pdf
Like any other amplifier you can drive two inputs with
opposite phases of signal and place the loudspeaker
across the hot outputs. This presumes the channels share
a ground.
Also, you can try sharing the feedback loop of the two
channels by connecting the 680 ohm + cap to each
other instead of running them to ground.
nice detail
me found a string to ..........
