Does crossover auto simulation software Exist?
I have wave files of my impulse measurements.
Is there anything on the market that takes those measurements and optimizes a crossover for them?
I am not sure I understand your question but LEAP will generate a crossover using a Wizard format more or less automatically. It can also run circuit optimizations against a Guide curve as well from an existing circuit and measurement set.
Rob🙂
Rob🙂
Yeah, that is what I was trying to ask. I forgot about LEAP. But Madisound LEAPs program only works for drivers they sell.
I have wave impulse files and I would think a software package could take those files and create crossover simulations.
Rob🙂
Hi , I wanted to ask this for a while, Do you think It worths applying that onto an LF something like a JBL 2235h ?
Or rather HF benefits?
BTW this one can do it , too, be sure to watch tutorials:
(((acourate)))® - Room Correction, Speaker Optimization and Sound Improvement
thanks!
Crap, The STransform software package can not import Wave files yet. Would have been cool to see my response in 3D. I have to see what other types of files HOLM can export.
Trying out Acourate demo....very, very limited.
pretty well I get to this point (imported my wave files)
But I can not do much more. I have to find some help files on it.
Well, there is a lot to read there, perhaps start with the whitepaper If you seek for phase coherent design apart the usual inverted frequency plots.
As far I understand the basic concept , you want to generate those correction coefficients afterall and those can get LOOOOONG both in terms of computational resources and processing time involved, so I pretty much gave up on it because its not really suited for my embedded app. Im toying with an esl57 now anyway.
-No passive crossover , passives can't do what is depicted in the whitepaper.
So its really a PC based DSP solution? It won't generate values for me to plug into my DCX?
btw, I like the interface.....not hard to figure out. Measurement packages seem to fail at that user ease of use thing and the toturials are great.
Ah its whole different than the DCX, this one is brute force FIR, whereas the DCX is rather cheap analog-alike IIR algo.
Also this one prefers low order filters , and using low order filters is mandatory once you stay phase coherent .
I just dont beleive the DEQX marketing fluff that its both steep and both phase chorent because byproducts cancel between drivers.
Im not looking for a discussion on DCX SQ type stuff.
Im looking for software that will take my wave files and build crossovers from it.
I believe LSPCad's "Optimizer" function does what you're looking for. Plus a pant load more...
http://www.ijdata.com/LspCAD_optimizer.html
However it's no where near cheap... ~800Euro😱
Thanks, I figured it would not be cheap.
I have been playing around with LspCAD (demo) for a bit.....its one of those non-user designs that takes lots of reading to figure out. I know its probably one of the most popular choices though.
Its just fundamentally different, and if you follow the design guidelines its clear its a whole other branch of the tree . It can build your crossovers - for use with a PC . It needs to be that different to have single digit hertz accuracy, which it is.
Why do you say that...? It will build passive X/O networks for you, and state the component values. You can afterward tweak the component values to match more common values if you wish.
...plus, if my memory serves, LSPCad X/O networks can be downloaded directly to DCX2496.
Im talkin about acourate™ not even saw your post. Its not a "virtual analog" approach like the DCX.
My mistake...
I didn't see a quote referencing anything about "acourate" so I assumed you were replying to the post preceeding yours.
Yes LSPCad can do the download but you still need to manually create the crossovers. (deciding slopes, etc). I want something that optimizes it all for me so I do not need to do it 😀 Right now its just other hobbiest that love building crossovers from speaker measurements. It would be cool to have a program attempt.
Again, my mistake...
I don't own LSPCad, and only quickly played with the demo. I thought you could use the Optimizer to create your X/O, and use that result for either a download to a DCX or view the passive design. Which you would build accordingly.
I would have to think that X/O design schema and slope is a matter of personal taste. I don't see how any SW could "optimize" something that's a matter of opinion.
I think its not really a matter of taste as much as we want to think ( Of course audio is ruled by subjectivity and it shouldnt be, yeah its art work 😉)
The crossover is there to do the littlest damage as possible, its simple purpose is to allow two or more drivers to work together seemlessly. Software can run 1000s of iterations to get it right, it can look at phase, etc and just keep simulating way beyond what any human can do. We do mathematical simulations all the time in the engineering world because a long time ago we figured out people are way, way too slow to find all the right combinations.
Once the proper crossover is decided then people can tweak the sound to their in room liking with DSPs.
- Does crossover auto simulation software?
