Does a stock elmo 305 sd need modification if used with a lcd (monitor)panel?
The elmo doesn't have a triplet lens (I'm pretty sure). It totes what it calles a varifocal lens.. but the word is that it isn't as good as a triplet (I think crus has an elmo and a 3m 9xxx and did a comparison)
Of course I could be talking out of my *** so don't blame cruser if this isn't the case 🙂
Essentially you can use a stock Elmo, as Video Freak said, you might want to split the fresnels.
Either way I think the Elmo is probably a good place to start 🙂 Once you have it you can always modify it.
-rep
