if you are a skilled builder it could work.
Amp 6 is 43X100X40m:
a toroid is usually; 120x50
speaker posts and electric cabling might pose a problem.
Check out:
http://www.kjxaudio.com/kj1.html
According to his parts list he's used a Hammond 1455T2201 case. You could check the dimensions for that case against the one you've spec'ed and then extrapolate from his pictures whether or not it would work. Personally I think it would be too tight.
