Hey everyone
So i was wondering if you have seen any 3D Cad Plans for a Waveguide for the Scan Speak D 3004/662000 tweeter?
Can be paid or free i don`t mind paying for it.
Any hints would be much appreciated
Awesome thank you!Somasonus WGs for 6600.
I took a swift look. I see that on the 6600 there are screws going through the faceplate while on the 662000 they are not visible (i think they are attached from the other end). Have you used it?
Cheers!
Sweet!The screws go from the front, same as 6600. You will need to remove the foam. Try to press with the finger at the place of the screw against the faceplate.
Thank you very much. Its much appreciated!
