I have worked on a cart made of a wooden tablet and 4 wheels to carry my subwoofer, but I have some worries I would like to ask you guys:
I noticed some shake and I am worried about it damage the internal components of the sub. It shakes when I carry the cart through a stone non leveled terrain.
Should I add shock aborbers to the cart or if I go slowly through the stones is Ok?
The wheels are huge 15 centimeters of diameter each.
Later I can share here a picture of the cart.
Use pneumatic tires instead of hard casters. The internal components are not that fragile so some shaking isn't a big problem but you should do what you can to prevent exposing them to heavy shocks like what happens if the cabinets were dropped onto a hard surface
It is a subwoofer. It spends its life being shaken from the inside.
I agree^^^ Ties with air in them will go much smoother. Also hard wheels are a lot more difficult to roll over things like cables and doorjambs.
Thank you.Use pneumatic tires instead of hard casters.
I will try to add above the cart a carpet made of elastic material to absorb the shock I hope it will work.
Yoga carpets would be a good choice? I don't know haha. I will try to get some thing good to put under it.
Hey guys, if someone is interested in visualize it, my cart picture
20210520-213325 — ImgBB
Thanks again Conanski and Enzo for the replies.
I don't think so, the product should be resistant against acoustic shake in maximum power.It is a subwoofer. It spends its life being shaken from the inside.
There is plenty of moving air and changing pressure gradients inside these. Having operated them professionally for many years, I will attest that in my experience, things do come loose.
But beyond that, it all gets loaded into a truck and hauled to the next gig, and the road shakes things up regularly. The equipment is designed for this use and holds up remarkably well. Over the decades I was never concerned about the trip from truck to the stage so much as I was the trips down the road.
I agree with Enzo.
From time to time we have to pick a screwdriver and tighten all those screws...(You know those powered speakers with 20+ screws to hold the amp plate...& 20 more to hold the inside amp cover.. and then the jack nuts.)
The cheaper the stuff is, the more screws You have to tighten or replace / glue broken stuff.
It's called maintenance, like blowing the dust from amp's fans.
That cabinet looks like an excellent candidate for a two-wheel dolly. If you could find one cheap enough, with pneumatic tires, maybe even semi-permanently attached to each cabinet.
The pieces I've had with 4 casters rarely rolled in the exact direction I wanted them to. At the least, I would consider replacing two of them with fixed wheels.
Just a thought.
Cheers
Just a thought.
Cheers
Wow, that is a different idea. Cool Rick! Thank you.That cabinet looks like an excellent candidate for a two-wheel dolly.
Yeah it is absolutely true, a person without motor coordinate control can crash the subject in somewhere. Unfortunately, my wheels are all spinning wheels lol and it is true.The pieces I've had with 4 casters rarely rolled in the exact direction I wanted them to.
The best cart is the cart that works for you and your money!
- Live Sound
- PA Systems
- Do wheels of PA cart need shock aborber?
