Do U even SMT bro!?
With the increasing necessity for using surface mount components I was wondering if you could share some practical ways of handling them and soldering them? Also I'm not able to print PCBs so it's all perf-board or pad-board for me.
I did build myself a little alignment jig for transistors, but it's still like playing pick-up sticks with my butt cheeks:
To test them I use a cheapo multimeter that has an inline hFE socket and some bent lead wires wrapped around the transistor:
How do you even keep track of them? I have nightmares about losing my precious Toshiba BJTs.
This thread was a good start but didn't actually include much technique.
https://www.diyaudio.com/forums/solid-state/3240-smt-practical-diy.html
I do have pretty good eyesight but nevertheless when I first had to solder SMD parts (down to 0201 & 01005), the eye opener (no pun intended) for me was that I could do it easily with the help of a good microscope.
Your experience may vary but in order to keep hands steady a magnified view helps tremendously and can´t be understated.
You can get yourself magnifying glasses like I did.
Not the most comfortable to wear because you have to get near to your object and will most probably not sit straight when using the highest magnification. But it´s OK for a couple of hours with breaks.
Of course that still won´t be comparable to a microscope.
I´d dare say that everybody can do SMT down to 0603 at least with magnified vision and a proper soldering tip (it also helps if if the soldering tip is not too far away from where you grip the soldering iron with your thumb; so similar to holding a pen). And I mean also on perfboard and making connections with insulated copper wire.
Oh, you´ll need proper tweezers too!
For protos, just use SOIC and 1206 parts, they're very easy.
I´d do the same. As big as you can, higher max.power dissipation and the savings in space and parasitics are plenty already with 1206.
What necessities do you mean?
I mean some parts are only (easily) available in SMD, like substitutes of the beloved LSK170 FETS or so but other than that I don´t see a necessitiy to go to SMD in audio power amplifiers.
If you want 6 or more really complex boards pre-assembled it might be the better/cheaper option.
If you don´t mind designing them, getting them produced is cheap enough these days, right?
The only low-noise BJTs I have left by Toshiba are SMD (1163/2713). The equivalent through-hole transistors are all unobtainium
I basically have abandoned through hole parts where possible even in my tube designs.. LOL I would say other than tube sockets, pots, connectors, electrolytics, film caps, big power resistors and power mosfets/transistors that need to be heat sinked I use SMD and that would account for 80% - 95% of the components in my designs.
I am reasonably good at designing PCBs and enjoy the process. PCB are cheap now so where before I would have used through hole parts and breadboard to build projects, now I design PCB and get them made. The amazing thing is they generally work well even if I made a minor mistake and a little rework is required.
I use 4 layer boards in a lot of designs and not too long ago made a minor but fatal error because the mistake was on an internal layer. I scrapped those PCB and almost all of the parts on them and made new PCB.
A lot of parts are no longer available in the U.S. at least as through hole. I actually like SMD parts better in most instances.
I use SOT-323, 223, 23 transistors, SOD123, SMA, SMB diodes, SOIC and VSSOP IC packages, and caps/resistors down to 0603. I used to favor 1206 size resistors and caps, but my latest designs are all 0805 because they allowed me to shrink stuff.
For PCB fab I use JLCPCB and Oshpark. My EDA tool is KiCad.
Thanks to all who are providing good advice. The writing us on the wall as far as through-hole goes. I might be a budding middle-aged hobbyist but I also recognize what is needed to inspire a new generation of hobbyists... and they're all going to need tweezers and microscopes.
+1, that's how I feel about it.. I'm in my mid 60s and made the switch to SMD about 5 years ago for hobby related stuff.
I used to have a guy who did PCB design for me, but I got tired of paying even the reasonable sums involved, and where humans are involved mistakes happen. I decided it was time to do it myself. The initial climb to competence was steep, but my earliest designs actually were mistake free, as I became more confident that's when I actually starting goofing up.. LOL I found I actually like designing PCB, it's both challenging and relaxing at the same time.
KiCad is free open source EDA software, and it's quite good. I have some familiarity with Altium (way too expensive for hobby use IMO) and OrCad - I have a license for OrCad but much prefer KiCad...
I love SMD's ! Been soldering them since late 80's .
Just recently I started with tssop's and sc-070 , these are with "feet" 0,65 mm apart, 603's and similar sizes for diodes/caps and 805 LED's. Still doable wearing 2 sets of glasses at once so you don't loose 3D depth of view. I don't have access to factory made PCB's , I mill epoxy boards myself , even for TSSOP's . SOIC's are easy . So try that instead of the pad-board you show , kwadrofonik.
Like the others said : tweezers . A woorden toothpick to hold them down and a selfmade thingy to hold down SMD's bigger than 805's. Of course a very fine soldering iron.
I use through the hole ones as SMD's by cutting some or all of their legs.
