Do these specific PAM8403 boards need a preamp?
This particular IC has an input voltage range of .5v-1.2v according to the datasheet. I could not find the input Z but given that their test diagram shows a tone generator hooked directly to input I don't think you will need a preamp or buffer. A CD player has a 2v output at its RCAs as a standard, for your reference.
Consumer-grade players have an output in the .75 volt range, the manufacturer expects them to drive either headphones or powered speakers, so no preamp should be needed.
The LM386 is an excellent chip for its purpose, but nobody has ever accused it of being hi-fi (except in the Headbanger headphone amp). You can't really make a direct comparison.
EDIT: Or, as SonyFan says, 2 volts. Either way no preamp.
