Do I need to reform brand new PSU caps for a tube amp?
Caps are new CDE Illinois 47uF/500V
Amp is original Peavey Classic 30
Supplier is Mouser
Can I assume that these are new enough that they don't need reforming before I install them?
If I DO need to reform them, the best I can do for now is 50VDC and then 100VDC with the equipment I have on hand...
If I install them as is and let the amp idle for a few minutes or hours will they reform (at lease somewhat) while the amp is idling?
I want this amp to be as hum free as possible.
I don't know about your PSU caps, but caps in photo flash don't take ling to reform. Just a few flash charge/discharge cycles and they are ready to go again. I can't think yours would need more than that, if anything. Just install them and use them - they will take care of themselves.
Even "new" electrolytic capacitors can actually be years old, having sat on the shelf in the warehouse(s).
There will be a 4 digit date code on them, consisting of the last two digits of the year of manufacture, (00 to 99),
and the month (01 to 12). At least some reforming through a series 10k power resistor is best (in the right polarity).
Never connect capacitors to be reformed directly to a voltage supply, the current must be limited (with 10k resistor).
It's odd that my caps DO have a date code, but it is just "29". Can't believe it means 2012_09. I called Illinois Caps to get it deciphered; everyone out for vacation until tomorrow. Meanwhile the protocol for reforming is minutes to an hour soak at progressively larger voltages like 100, 200, to the rated limit, through a 10K to 33K current limiting resistor of 5 or 6 watts.
What I have is a vintage HP (later Keysight) 6228B dual DC power supply. No high wattage resistors bigger than 50 ohms and no Radfio Shack in the mall any mire. I can dial in current limiting in the HP which should work. I can daisy chain the 2 50V sides to get 100V max and limit the current to 500mA (I think, never tried it before) so I could give them an hour at 100V even if the date code turns out to be fresh (<6 months).
So All Is Well. Thanks.
Will do (limit current to 10mA).
Found out that the date code of "29" means 2nd half of 2019, i.e. a bit more than a year old. So I'll do what I can to break them in. I have an HP 6228B dual dc power supply. With the dual outputs in series I can get to 100Vdc and can control the current. I'll test how low it can go before I install the caps. Wish I could go higher, but I give them a good few hours at 50V, then 100V, and then put 'em in...
