Do I need to insulate the center bolt securing a toroidal transformer?
I was reading some stuff that seemed to indicate that the center bolt holding a transformer down should be insulated from the chassis, or better yet, not be conductive in the first place. Is this right? Or, is it important? I’ll be mounting the transformer on the steel bottom plate of the case, with the included rubber washer/pad.
The metal mounting bolt must not touch the chassis at both of its ends, or that would make
a shorted turn in the transformer. Only one end of the bolt may touch the chassis.
Very important.
A steel bolt without insulation is OK if there is no outer can or other path from the top of the bolt to ground. If a metal outer can is placed over the toroid, and it is not insulated where it contacts the chassis, then the bolt through the center must be non conductive or insulated.
You must avoid creating a complete turn through the transformer that is shorted, as this "shorted turn" is the same as a one turn winding on the transformer with its output shorted.
Shorted turn illustrated:
If you mount a toroidal in a slim-line chassis its wise to insulate the part of the case than could touch the top of the toroid if the case were accidentally compressed/dented at that point - or put a plastic cap on the mounting bolt to avoid the possilbity of a short (which would spot-weld itself otherwise).
I assume this doesn't apply if the mounting bolt doesn't touch the cover? Like this style that mounts to chassis in the corners?
  • GD-PARTS-1PC-150-65mm-Black-Iron-Round-Amp-Triode-Vintage-Transformer-Protect-Cover-Enclosure-Bo.jpg
I did not know stainless is usually non-ferromagnetic... I've been using brass hardware wherever I want that property, but stainless is easier to find.
Right now I'm doing something like knauf's picture. It's insulated at the top and bottom with washers, but I can't guarantee it won't **** to one side and short to the chassis, as I don't have a grommet on it.
I'll have to find a big nylon bolt somewhere. No where local stocks anything that big.
