Do I need an ultracurve 2496 EQ
Does anyone have experiance with the Behringer Ultracurve 2496?
I read a lot about this digital equalizer but I'm not sure if it will work with my Magnepans. Maby the frequency curve will be flat but the sound quality by use of this EQ is after all more destroyed.
At this moment my equipment sounds very clean and detailed, thanks to a lot of exchanging of cap's and opamps but it's hard to get the subwoofer and the Magnepans in line.
Does it make sence to tune the ultracurve (cap's and opamps), so it will fitt the quality of the rest of my system?
My sub is a Peerless XL10 with passive radiator and a Hypex amp ajustable x-over between 50 and 150Hz. Also a plus 0-6dB adjust between 20 and 50Hz.
Magnepans are MG12SE.
Thanks for info and advice!:smash:
