DNM Primus 3B
I have a DNM Primus 3B in mint condition. It just came back from the factory for check and update. I have the receipt about was has being done.
It has a Phono MC input and 3 line inputs.
This one was manufactured in Switzerland. One of the finest preamps ever build.
I would like to get 1200,- € incl. shipping.
Denis is a master of the delicate and detail with his designs. The poweramps gave me a shock when I first heard a PA1 - sounded so much more powerful and in control compared to the much more powerfully specified mono blocks I'd been using previously.
The DNMs are always beautiful to look at in an electronics point of view but if you're not currently using it because of your own designs then might as well put it up there for sale, see what happens.
Another snipit of info on this 3B is that it can be run with a pseudo-balanced output (in order to work with the PA2 monoblocks). I think that means the signal ground is floating? There are a few jumpers to change in order to do that. That's why I had mine for a while, with some PA2s.
Then I went active for a while so moved on.
I have a 3A Twin at the moment which should also be easy to convert to a six myself at some point but it suffers from input sensitivity to CD output levels - which was solved by the time of the 3B.
