I tried to measure a 7915 regulator on my HP3478A 5.5 DMM. With correct polarity (Lo=-15V & Hi=GND), the reading is -15.82xx volt, but if I reverse the test lead (Lo=GND & Hi=-15V) the reading becomes +15.63xx volt! According to service manual, there is no calibration on negative DC, and all calibrations on DC is only based on positive reference. So, I don't think a full calibration will solve this problem. Is there anyone having this problem?
One of the tests for a correctly working voltmeter is to check it reads exactly -Value = +Value when reversed.
It sounds like your meter has developed an offset. What do you get when you short the inputs to the meter?
I don't know if that's a bench type or a hand held. If the former, it could be leakage to the power line. Does it have a ground lead or are both leads floating?
It's a bench type DMM. When both leads are shorted, it is about -0.0014mv ~ -0.0019mv. I will try a 12V car battery next time.
Any battery will do... 1.5 or 9 volt etc.
It's possible the error measuring on the reg is down to some noise etc on the rails or AC "noise" on the chassis (ground), so reading a battery will prove beyond doubt. I would guess with a meter like yours it should be equal to within the last digit or so.
- Design & Build
- Equipment & Tools
- [DMM] Different reading on reverse polarity
