diyAudio.com needs a new logo. For this reason we have decided to host a competition. There will be a prize for the winner. Final submissions will need to be high resolution suitable for print.
Great idea.
How does this competition work? Any email adress for the submissions? Or posting it here?
Are there any limitations on the submissions (number of colors, desired format, ...)?
Awww, I've become so fond of the current logo and website graphics... feels so comfortable, kinda like home. 🙂
I guess I'm wondering what needs to be printed... ? Are we adverstising in magazines now?
Merchandise.hifiZen said:what needs to be printed
No.hifiZen said:Are we adverstising in magazines now?
HBarske said:Great idea.
No limitations at this moment as long as the final submission is in a format we can work with.
Draft submissions will be in another thread.
Final submissions will be via email or direct upload. (Haven't decided which yet.)
More details
We also would like a mascot designed ... It's probably better if we get the mascot done before the logo so that the mascot can make an appearance in the logo. Now's I've just got to go and see if I can organise 2 prizes.
Once I've got the final art, I can optimize for each medium. Please focus on producing something suitable for print.
If you're printing the logo (postcards, business cards, or letterhead), will you want something that uses normal 4C CMYK inks, or are custom Pantone colours okay? T-shirts can be silkscreened using pretty much any colour of choice, but, there might be limitations, depending on the place printing them.
Does the logo need to be adaptable in terms of proportion or colours used, or a fixed design that is set in stone? Web banners, because of the odd proportion, might affect how much you might want to alter the base logo to retain its integrity. The need for a more flexible design will present different considerations than one that can only needs to, or can work one way.
Does the mascot need to be part of the logo, or is it something separate than should or could incorporate stylistically? Does the mascot need to be designed with further uses other than print? 3D figurines, plush dolls, key chains? Limitations in molds will need to be factored in, should you choose to get ambitious.
I originally meant to put a comma between 'can only' and 'needs to', but, realised that the 'or can only work one way' was redundant.
so, it should read as:
The need for a more flexible design will present different considerations than one that needs to, or can only work one way.
should read as:
Does the mascot need to be part of the logo, or is it something separate that should or could incorporate stylistically?
should read as:
Jeff Wong said:If you're printing the logo (postcards, business cards, or letterhead), will you want something that uses normal 4C CMYK inks, or are custom Pantone colours okay? T-shirts can be silkscreened using pretty much any colour of choice, but, there might be limitations, depending on the place printing them.
It's probably best to limit it to standard CMYK.
Jeff Wong said:Does the logo need to be adaptable in terms of proportion or colours used, or a fixed design that is set in stone? Web banners, because of the odd proportion, might affect how much you might want to alter the base logo to retain its integrity. The need for a more flexible design will present different considerations than one that can only needs to, or can work one way.
Once the design is done I'd like to be able to keep it the same for each purpose.
Print / web banner only. Should be designed on it's own and the winning mascot should be incorporated into the logo in a stylish manner.Jeff Wong said:Does the mascot need to be part of the logo, or is it something separate than should or could incorporate stylistically? Does the mascot need to be designed with further uses other than print? 3D figurines, plush dolls, key chains? Limitations in molds will need to be factored in, should you choose to get ambitious.
Do you want the logo to only read diyAudio.com, or should it include the tagline, "projects by the fanatics, for the fanatics"?
Does the 'diy' portion need to be in lower case next to the capitalised 'Audio', or can it be in caps, as long as it is still readable (separated by a colour perhaps)?
Should the design be made to fit the Bulletin Board proportion of 332x76?
Is the smallest usage going to be for a business card, or something smaller, like a 6mm CD spine?
Do you want the colour to tie in with the existing BB colours?
yes it should.Jeff Wong said:should it include the tagline, "projects by the fanatics, for the fanatics"?
would rather the spelling be left as it currently is.Jeff Wong said:Does the 'diy' portion need to be in lower case next to the capitalised 'Audio', or can it be in caps, as long as it is still readable (separated by a colour perhaps)?
no need.Jeff Wong said:Should the design be made to fit the Bulletin Board proportion of 332x76?
business card or larger.Jeff Wong said:Is the smallest usage going to be for a business card, or something smaller, like a 6mm CD spine?
We are looking at doing a complete make over so no real need to keep with the current colours.Jeff Wong said:Do you want the colour to tie in with the existing BB colours?
- Site
- Site Announcements
- diyAudio Logo Competition
