DIYAudio 12 Channel HT Amplifier
Looking for suggestions on a build I want to do. I'm new so I'll need some guidance-
Looking to build a 12 channel class D for HT use. I have a $300 USD Max budget. I've seen the TDA7498E suggested and says it has it own power supply. If this is a great way to go, what else is needed?
I guess if you had $300USD to get all the "guts" for a 12 channel, what would you buy? Case I'll worry about later. I'll probably try to find a old amp to gut and use as chassis
