Diy Xlr-rca cable
hi guys, i need some info from you experts. i am building a signal cable to connect my dac to the preamp. the dac has only balanced xlr outputs, while the preamp only has unbalanced rca. not to use rca-xlr adapters I enjoy building some nice cables. the designer of the dac told me that the connections, in the specific case of this dac, are: phase + on pin 2, phase - and shield together on pin 1, pin 1 connected to the connector body to the chassis. pin 3 remains disconnected. So far so good, but I came across this Ramm Audio Elite 8 signal cable, which has not two conductors plus the screen, but 3 conductors (Green, red and white(?))plus the screen. how do i connect them? two conductors on pin 2 and one with the shield on pin 1, or one on pin 2 and two with the shield on pin 1?
