DIY Sub Plans
I'm looking to design a sub that would cost in total $400 or less (preferably less). My main criteria is I want it to play very deep (18-20 hz +/- 3dB) and it has to be musical (home theater volume not a concern). Any recommendations on drivers, amps, and/or plans that could fulfill this project?
Thanks,
Nick
I would recommend you to build a Adire Audio Tempest subwoofer with a EBS vented alignment.
You will need:
2x Adire Audio FP4 4" Flared ports
1x Rythmic Audio 250W subwoofer amplifier
1x Adire Audio Tempest subwoofer driver
Total cost 323$ shipped at your door + wood + 64 oz of polyfill
But then, it's big, you need space, 48"x24"x24".
an auto tuba (single) simply cant compare to the swept volume of a tempest, and the tuba 18 wont even reach infrasonic levels. Then again bills horns are designed for efficiency, and m yhat goes off to him for that! In the pro audio realms they get loud and low. Tempest and the typical horn are completely different animals.
No offence Bill, this is my opinion and feel free to disprove me
Nm2285 said:
How do I determine the room lift? My room will be about 14x16
Simulate it
with this
It will show you both room modes and room gain. Just watch how you enter in the reflectance values of your room. Solid masonry will be 0.9 or higher, framed drywall more like 0.7 probably. This gives better info IMO than generic room response curves. Room gain also is related to placement.
