diy speaker cable
Before this devolves yet again another one of "those" threads - I always tend to like the cabling on which it's easy to identify conductor polarity. Note that with wire this thick, even with pre-tinning, the amount of heat required to get a good solder connection can often melt back the insulation, so I like to dress up with a small length of color coded heat shrink tubing if the spades don't already include booties.
comparison-from what I understand Southwire is tinned copper strand and the other is OFC strand which is more conductive but more prone to tarnishing over time. soldered ends and heat shrink should do away with most of that. Is there any sound quality different if using the same solder and spades?
Markertek.com offers free shipping and good prices in the USA.
Blue jeans has another site selling unterminated cable called rawcable.com
Personally, I use the blue jeans belden 10/2 and 12/2. Canare 4s11 would also be on my list for cheap cable.
Any question about the 'sound' of speaker cables is bound to turn into one of 'those' threads. The only question is how quickly this will happen. This is simply because people of one persuasion cannot bear to see advice from the opposite persuasion lead a newbie astray, so whichever school of thought you belong to you can only remain silent for a while.
