Hi All. New to these parts of diyaudio.com
Anyway, it might already be her somewhere but I can't really find it.
Has anyone done a good upgrade clock for use in DVD or CD??
I'm going to do some moding of my otherwise perfect Denon DVD 3910.
I actually like the sound very much, but I guess I can get a little more out of it by modification.
I'm not going to spend a lot of money on this project, as I guess the money would be better spent on a new and better DVD.
Therefore I'm not prepared to spent 150 Euro or more on a new clock from Tent, DEXA or other quite expensive alternatives.
Has anyone done something similar, using more standardised components with good results???
Bessides a better clock I'm considering changing the op amps in the I/V and buffer stage.
As I said I think it is already a solid construction and I'm not expecting to get a night to day experience in sound improvements.
Thanks in advance and kind regards Baldin 😉
Hi, What' s the frequency you need?
Some have built the KWAK-CLOCK for DVD with good results.
http://www.diyaudio.com/forums/showthread.php?postid=199928#post199928
Thanks that's what I was serging for.
I wonder how this clock 7 would perform and sound to more established solutions from LC Audio, Tent Labs etc.
Has anyone tried it out in a A/B setup with on of the other solutions???
It's quite a lot cheaper solution, but will probably be an improvement to the clock in my Denon DVD
Just read a bit about TI's CDCE913. Seems like an alternative to the Kwak .... anyone tried this or has any comments?
http://focus.ti.com.cn/cn/lit/an/scaa088/scaa088.pdf
http://focus.ti.com/lit/ds/scas849b/scas849b.pdf
Baldin said:Just read a bit about TI's CDCE913. Seems like an alternative to the Kwak .... anyone tried this or has any comments?
you did not notice the red phase noise spikes?
Elso Kwak's clock is a well regarded DIY clock that has been around for quite awhile. Also, he still sell kits at reasonable prices. I believe you can contact him at elsokwak at home.nl
Regards,
Dan
Hmmm you might be correct. I don't think it is that obvious what the graphs are showing.
I asumed that the green curve was the output and the red the "input". In the text relatively low jitter walues are mentioned both in RMS and p-p values
avoid synthesizers if you want to build serious clocks
above all, for a CDP / DVD you "just" need a good master clock
best
Ok. I think I'll try the Kwak Clock 7.
It should be pretty easy to convert it tosingle +5 VDC.
Also thinking og using a shunt or actually two on for the oscillator and one for the comparator.
I'll use the crystl that is already in the DVD, and a MAX913 or a LT1016 as I already got one these.
Will try to get the J309 ... but might have to substitude .... any ideas of a more common type that will do?
Cheers Baldin 🙂
Cheers Baldin 🙂
- Digital Line Level
- DIY ref clock for DVD/CD
