DIY portable USB headphone AMP/DAC- recommended ICs?
I wish to make a small, USB-powered USB audio solution for use with headphones.
Is there something better I could use than say the PCM2706, while still being practical? (I hope so!)
I'm fine with making PCBs, working with SMD, etc. I'm not familiar with what chips would be best for this though-- what I would use for a home set up would sound great, but not be possible in a reasonable size or all from USB power. What is the best I can get that fits these constraints?
A one-chip solution like the PCM270x can offer would be great - but I have no problem with a multi-chip solution provided it works, and I'm assuming this is what is probably needed to get the best sound.
To get the "best" sound can depend on how much $ you want to spend.
PCM270x is a good starting point.
Adding a seperate D/A chip will improve the sound.
WM8524, AK4430 and ES9023 are pretty easy to implement.
There are much better USB receiver chips than the PCM270x but
they all suffer from NDA and having to deal with the manufacturer or
you need to be pretty handy with programming.
If you're after the best sound (and from what I'm reading it seems you are) then start with a TDA1387. I haven't found better sound at anywhere near the price. It takes I2S input so it'll need a USB adapter chip that puts out that. After the DAC you can use an AD815 which works at 5V quite nicely and it'll do I/V duty as well as power your headphones (it has minimum 400mA output current capability).
