DIY One fader mixer with Filter Low Pass, Hi Pass, Notch Pass Filter PGM
Hello,
I was wondering if this would be a hard DIY project. I'm looking to build a one fader mixer with a one rotary knob and switchable HI/LO/BAND pass filter sytem. As seen in the VESAX PMC-CX
Vestax PMCCX Carl Cox Signature Pro 3-Channel Mixer - PlanetDJ.com
Would that be hard to do?
• NEWLY DEVELOPED FILTER EFFECT SYSTEM : An extensive amount of time has been spent for the circuit to be developed after "cut and try" with a number of opinions exchanged between Carl Cox and Vestax for each program channel to generate an unexperienced active groove. Featured on the HI PASS, LO PASS filters is a new system never seen before! With extreme intricate waves creating the fattest and biggest sounds while at the same time when you press both switches, it turns to create soft and natural waves generated through a dip sweep/band pass filter.
• VCA CIRCUIT AND HIGHLY RELIABLE 60MM FADER : Vestax 60mm railed faders are applied to both input faders and cross fader. With a VCA circuit, audio signals are passed through the faders and made possible to co-exist with opposite elements in having a smooth fader movement with volume control, yet keeping higher durability. The input fader is detachable and an optional rotary fader is also available. The cross fader curve can be adjusted to any type of performance with the help of the VCA curve control.
