DIY mitsubishi wd 57831 projector dlp tv
hi. how to remove ballast and use the fooling bypass for mitsubishi wd 57831 fullhd projector rear dlp tv.
this model use the 938P069A10 ballast
5 pin osram controller. (attachment PDF - fig4)
pin1: lamp lit
pin2: GND
pin3: 5 V+
pin4: SCI
pin5: DIM
i want to remove and delet ballast & lamp controller board and replace led 100watt . 😕🙁
i used 12v+ from main board for led but tv 3 attemp to power on then error 57 (ballast problem)
