DIY F2 distorting BAD in one channel
Howdy
As of yesterday, my F2 has started distorting BAD. It sounds like it's happening mostly in then upper midrange.
It worked fine for years but then recently I decided to finally put a case on it. This required pulling it apart completely and putting it back together.
After being cased up it worked fine for at least a day. Now it's ****** in one channel. Prior to this, it had been on for a few hours, so my guess is that it overheated (since it's now in a case (ie less airflow).
Any thoughts what could be the cause? Ripping off the mosfets will be a [pain, so I'm curious if there's qany likely causes?
Hugo
