Does anyone knows of a design with the Visaton FRWS 5 that could be used as a computer speaker? I would like to make a small pc speaker for use at the office so it has to be:
- cheap in case it falls off the desk
- only needs to play very softly as I don't think it will be tolerated at normal volumes
- small as my desk is already overflowing
I could use some of those plastic pc speakers but were is the fun in that? Something that looks a bit out of the ordinary or plain weird would be more suitable.
just for fun I once designed a TL which had 3 of these in, 1 as midhigh, the other 2 as low. never heard if the guy actually built them...
the middle one in a 75cc enclosure, and gets a HP filter of 27uF (or 33uF) (reverse polarity), the other 2 mounted in series with a LP of 2.2mH and 47uF
but it can also be single driver of course:
this one actually was built 😀 depth of the cab half of the other one
edit: I see you're from Belgium, so you might be able to read the original threads on these two
http://forum.zelfbouwaudio.nl/viewtopic.php?t=7204
http://www.zelfbouwaudio.nl/forum/viewtopic.php?t=6749
sizes see the attachmentthe middle one in a 75cc enclosure, and gets a HP filter of 27uF (or 33uF) (reverse polarity), the other 2 mounted in series with a LP of 2.2mH and 47uF
