DIY amp for active subwoofer?
This is a first time for me to build an active sub- Just starting to draw up a design using a single Jordan JX150. I think it will be BR. The crossover point will be around 95 hz.
For the box I will use corian and will put a thick acrylic window in the top. I need an amp rated to about 150 -200 watts? The box will be quite low so I can slide it under a sofa, ie 12cm high max
