DIY 300B - fuses question
Hello guys!🙂
I am building from scratch a 300B - audio note kit 1. From scratch means I purchase separately PCB's and all the components from various sources. Very enthusiastic about this project despite the fact that I am a mechanical engineer with rather limited electronics knowledge.
I need now to plan for the fuses. Noticed in some step by step instructions from Audio Note kit that main fuse is a 2A slow blow.
Since I am in Europe with 220 V I will plan for a 1 A fuse - please let me know if this sounds right.
I have read all kinds of forum discussions regarding fuses on B+...etc.
Can you please let me know in a simplistic way if I need other fuses and where?
If "B+" is a option please let me know what B+ is. 🙂
Thanks!
Thanks!
B+ is the nomenclature for a power supply rail (its origin dates back to valve sets where B+ was actually a battery, hence the B)
You should fuse every rail in your product, from the incoming mains, to the rails on the secondary side of the transformer (i.e. all the B+ rails), you're protecting stuff further upstream from burning up (like wires for instance, transformers or other components)
