Distortion analyser circuit
there are two types of distortion analyzer you can build. first is a notch filter type. it's simple, but fixed frequency. it also requires a super low distortion oscillator. the second is a subtraction type where you use an instrumentation amp to subtract the amp output from the oscillator signal. it's a bit more complex, but the distortion requirements for the oscillator aren't as stringent, and it works at any frequency.
there's actually a third option.... use the sound card on your PC as the oscillator, and as a spectrum analyzer. you need to build a very good attenuator for your sound card, but it's a lot simpler than a complete distortion analyzer. a good freeware program for this is Spectrum Lab by DL4YHF. it can be used with full duplex sound cards with up to 196k sampling rates. then if you want to translate db measurements into percentage, i'm sure you can find a chart of this on the web.
the 1kHz or 2kHz distortion is going to tell you a lot about the DUT -- so if you are in hurry build the Cordell oscillator (the basis for the Tektronix SG505) for 2kHz, run it off batteries -- it will yield THD% in the arena of the Audio Precision family. It's a lot less fussy than Bateman's, and you won't break the bank purchasing the opamps.
for $49 you can purchase the Texas Instruments ADS1271EVM -- it's a USB based -- you'll probably need an MMB0 mother board as well. The two are sold as a package for $149 from TI.
I don't know if you ever see them in the UK, but the later Heathkit THD analyzers were pretty good. I used a Heath IM analyzer and it worked as well as my Tektronix AA501.
Here's a GIF of the ADS1271's output.
http://www.tech-diy.com/TestEquipment/THD Analyzers/ADS1271/ADS1271.gif
i have one im thinking about building one that will use CFB op amps to improve the accuracy of high frequency measurements. regular VFB op amps begin introducing errors above their LF corner. (sorry for my lack of proper punctuation, but for some reason, every time i try to enter an apostrophe, i get a find window at the bottom of the screen)
Current feedback opamps are not very forgiving when it comes to layout. I found after several iterations of the Linear Tech Super Oscillator that it worked best when the two gain blocks were symmetrical in layout, and copper was poured all around. Not a great project for someone just starting out.
But what an oscillator:
