Discontinued Fostex, Mark Audio, Other, B-Stock & Left Overs
Frugal-phile™/Moderator
Joined 2001
With the change in the Fostex lineup i have some drivers that need to be liquidated.
First up is a pair of FE206eN. As i was doing final packing i managed to damage one of the whizzers. I used this as an excuse to try out GM's whizzer massage. It did a pretty good job. I had a couple people look at them for damage, they couldn't tell. (i can thou -- 3rd picture). If pristine these would retail for $390.
Black with White spots.
I'm asking $250 plus post.
dave
I haven't sorted thru the FE127 yet, all the FE126 are gone, i have the following singles (althou there are 2 of some i do not consider them pairs)
2 FE166eN -- full treatment includes phase plugs, Natural with Brown $65 each
1 FE167eN -- full treatment includes phase plugs, Natural with Brown $65
2 FE207e -- Stock but for phase plugs installed $90 each
1 FE206e -- Stock but for phase plug installed $90 (this one has measured TSP closer to FE207e, be ideal for someone looking for a 206 in a simplier centre channel.
I also have a few non-Fostex (i'll be rooting around in the next week as we clean up for diyFEST). At this point i can only remember a few.
1 pair Merril DCA5.5eN (fully treated, i need to check the colour) $100/pr
1 pair Tangband W3-871eN (fully treated, well matched, IIRC natural with grey) $80/pr
dave
Time to add some stuff:
FF165KeN prototypes $100/pr
These are in the Eastern US (NJ IIRC, so shipping will be from there (and a savings for US members). There are there as demo units for a fellow that had me do up the FF165K in his Cain & Cain SuperAbbeys.
cone treatment including EnABL (natural w grey), basket stiffening
This is the driver that Godzilla really likes in his BIBs (his drivers are stock). They lived in a set of Cain & Cain Abbys for awhile where they outperformed both stock FF165k & FE166e (driven by a DRD45)
The last of the FE127eN. All new.
A pair (not a matched pair, but the critical efficiency parameter is within the 1/4 dB i allow so could be used as a pair) $130/pr
2 singles $55 each, or $50 each if you buy both (or if you already own my drivers and are looking for a single for your centre channel)
These are EnABL2 and look like this:
Data attached... note that thou the 2nd set is displayed like a pair, from the matching numbers you can see that they are not. 1st one in gets to pick their single)
dave
Note: there is one more special pair, in a wild colour scheme, that will be put up for auction with the entire proceeds going to diYAudio.
