DIR1703 fs selection
Hi to all!
I'm trying to build my first dac using BB DIR1703 and PCM1728.
I have a lot of question about right frequency select on DIR1703.
I was read datasheet for DIR1703 for several time, but I still don't understand few things.
First of all. I'll like to build dac with 24bit and 96kHz compatibility.
If I use 24.576MHz crystal oscilator, set SCF0 to high, SCF1 to low, BRSEL to CSBIT and CKSEL to UNLOCK will my dac be able to receive any spdif frequency between 32kHz, 44.1kHz, 48kHz, 88.2kHz and 96kHz ? Is this correct ?
If I set DIR to I2S mode and 24bit output and the same mode on PCM - data will be trasmited correct, but I don't understand if this will work irrespective to input data which are 16bit from my CD57 ?
Leon
