Dim bulb tester socket 300watt
I think it is important to match the potential power of the device under test with the lamps, otherwise they will not illuminate brightly if you have an issue to investigate.
I used two sockets and two 40 watt bulbs in parallel. One bulb can be removed for a more sensitive tester.
What are you testing?
