😀 Screaming of Joy 😀
I have done it !
My prototype digital cross-over is working !
It is based on :
- A CS8420 to convert SPDIF to I2S Left justified
- An AL3101 DSP doing the actual algorithm
- An UDA1328 (for now) converting the filtered signal to analog
And as last, a 16F84 as controller.
The Algorithm is just an IIR of an 4th order Linkwitz-Riley, or better a squared butterworth. Later on i hope to do some FIR filtering
Now i can start thinking of making it more mature (advanced, whatever)
Let me now what you think of it !
grtz
Simon
I have done it !
It is based on :
grtz
Simon
The AL3101 DSP is too slow for FIR filters. FIR Filters need much more processing power then IIRs.
Even the ADSP 21065 (like in the Behringer DCX) has not enough
performance for good FIR filters.
Except you need`t for one channel.
How did you interface the PIC & Alesis chips? Does the PIC load the program into AL3101, where does it store it (on PIC there isn't enough FLASH to store the whole program)?
You can use it for FIR, though only ~500 point IR for stereo and ~1000 (maybe not quite) for mono filter. You first implement either the HP or LP and then subtract the other one (single cycle). For baffle step compensation and some other EQ needed (depending on drivers) you also need some cycles. Anyway, less than 100 points is OK for bare xover functionality. Problem is the latency (1/2 of the IR length).
The Program is loaded from a eeprom.
The AL3101 can do that by itself!
Can also be compensated for, by a delay !?Problem is the latency (1/2 of the IR length).
best regards
Simon
I am interested in DSP project with AL3101 DSP procesor, please send me more info PM. Thanks,
best regards
Simon
