Digital front end questions
1. yes, you can connect the deq directly to a cd player. You might connect it using rac one side, xlr on the other side - but you should use 110 ohm cable. A regular rca interconnect (around 50 ohm or lower)
can work - it did so with my micromega, but might not - as it did with my philips 963.
The wiring diagram is sketches in the deq manual.
You can use also the tosalink optical input of the deq.
But - what do you use as a volume control - or is the output of your cd player attenuable in the digital domai? Not a good idea, because by digitally attenuating you cut down on the bits the unit transfers.
Better a volume control between the deq and the following amp.
