Digital Filters - Slow Rolloff - better impulse reponse?
Hello. Can anyone enlighten me about the deal with
the slow rolloff option available in some digital filters?
Specifically I am looking at the BB/TI PCM1794. I have
seen very vague writings of improved impulse response.
But the stop band attenuation is greatly degraded too.
Does anyone have any experience with this? I am
wondering what, if anything, this might buy. And what
this potential improvement in one aspect might cost
in another aspect of the overall performance....
Zero oversampling, no digital filtering DAC has perfect pulserespons (before analog filtering that is), but mostly unlinear passband frequency response and fair amount of HF garbage.
An oversampling, interpolating digital brickwall filtering DAC has flat passband frequency response, high stopband attenuation (no HF garbage) but a pulse response as a rather long sinc.
With a slow rolloff digital filter you end up somewhere in-between. The slow rolloff sacrifice some stopband attenuation and passband linearity to get significant shorter sinc in the pulse response. IMO this is a good tradeoff.
/Jesper
/Jesper
Jesper
Thanks for contributing. The issue however is what final response will be when both filter types are combined
regards
Cameron,
This is not about the chip you mentioned, but almost perfectly answers your question generally.
http://www.dcsltd.co.uk/papers/effects.pdf
Pedja
Guido Tent said:
Jesper
regards
The analog filter after the DAC is of low order, probably 2:nd so its pulse response is fairly good. Also, the higher oversampling the higher the breakpoint of analog filter can be, thus shorten its pulse response. As a, result the contribution of the analog filter to the total pulse response is rather small.
/Jesper
/Jesper
Jesper
That is what I thought a long time
I suggest you simulate or measure on a combination of filters, one with overshoot, in cascade with one that rolls of slow
regards
Guido Tent said:
Jesper
regards
I'll do that when I have some spare time. Or even better, do you have a simulation to send me, Matlab would be great.
/Jesper
