Digital Designs Z1
I checked every compoent on the power supply driverboard and they all check good...
Amp will not power up at all ...
If i Hook 12 volts straight to the VGS pin of the driverboard amp will power up and relays click on...
Audio driverboard is out of the amp at the moment...
Any ideas on what to look for since the amp wont power up until i apply 12 volts to the VGS pin ??
This amp is probably going in the trash...
I got it off a friend and its seen better days...
Also i cant find the diodes that go on the Audio driverboard
Ive asked about 20 people including Digital designs themselfs and they cant tell me a part number for the diodes ..
I thought i ound the right ones but as soon as i power it up it smokes the power supply fets with thoose diodes in circuit ..
SO unless i can find 2 new driverboards Both power supply and Audio driverboard The amp is Garbage Since half the pads are burnt off and there are jumpers all over the place
