Differential output
I've used three different solutions:
1) Turn your symmetrical input amp into a single ended input by grounding one of the inputs(typically the inverting, but check your owner's manual). If you are using short interconnect cables this solution is often the best sounding....no junk in the signal path. Some amps do not really use a true symmetrical circuit topology, and put an extra diff-amp in front of their "real" amp to support symmetrical inputs from PRO audio(long cable folks). Check your owner's manual.
2) Use a BB OPA134PA opamp, or you can find a couple JFET input and bipolar output circuits with a DIYaudio search. I've build a couple myself. Never use two ordinary opamps in series to create + and - polarity.
3) Use a transformer for both isolation and symmetrical signal generation. JENSON has several application notes on the topic. This is common in PRO audio.
