Different top plate & wood base for 2A3 parafeed
Well, I thought this might give a little fun to see for other DIYers.
My local DIYers like this. 😀
Top plate with hinges and damper. Damn convenient to temper with.
You don't have to pick it up and put it upside down and open the bottom plate...
It's D3a trioded to parafeed bifilar interstage, then to 2A3 resistor loaded parafeed SE.
B+ is 48V Cisco SMPS in series I did after Greenvalves.
Reactions: ziffel
Yes, the wires were a little short and I pushed my luck. 🙂
They are 6AL5 diodes for cathode bias of 2V@20mA. It can be replaced by a small 100-ohm resistor but I like the sound of 6AL5. Maybe I need to do something about the heat.
