Just wondering why this inductor has leads of different length (I'm only used to seeing this on polarised capacitors). The datasheet doesn't specify.
19R154C | Murata 150 μH +-10% Leaded Inductor, 1.9A Idc, 129mΩ Rdc 1900R | RS Components
Purely for pick and place machines, it more difficult to insert components with equal length leads into a PCB rather than staggered leads, as you will know if you cut the leads from a component to equal length and then try to insert the component.
