Difference between Hertz HS-200 and HX-200
Hello,
I want to build the TNT PrimaLuce:
http://www.tnt-audio.com/clinica/primaluce.html
These are based on the HS-200 woofer which, according to my reseller in Italy is not available anymore. He assured me that the new HX-200 is usable in it's place.
Can somebody confirm this?
Since i found someone that has the HS-200 in stock in Germany, at 93 euro instead of 153 euro of the HX, I would spend this extra money if I was sure the HX are compatible with the PrimaLuce and actualy beter.
All suggestions are welcome
I'd definetely buy the cheaper HS-200 whilst you still can.
The HX-200 may be a "better" woofer but in the design
its very unlikely to be a better choice than the HS-200.
The best person to ask is the designer, who
also works for HertzAV so he should know !
🙂 sreten.
