• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
DHI PCB PROTOTYPE MANUFACTURER FLEXIBLE PCB & Assembly
Hi,HuanYu Future Technologies Co., Ltd is one of the China leading Printed Circuit Board Manufacturing Enterprises. Manufacturing Capacity24 hours turn time on double sides PCB's,2-4 days for multilayer PCB's.Producing over 5,000 unique part numbers per month .Current products manufactured include backplanes, hybrid pcb,HDI pcb, High TG pcb, High Frequency pcb, Halogen Free pcb, metal core pcb aluminum pcb mcpcb, Flexible pcb and more.Production CapabilitiesLayers count: 2- 14 Pilot run: 32 layersMin Line width/spacing(mil): 2/2Max Aspect Ratio: 22:1Board thickness: 0.13-7.0mm Max Panel size: 23"x35"Material: FR-4,High Tg FR-4,Halogen free,High Frequency,Thick copper,aluminum,Polyimide(Rogers,Arlon,Taconic, Bergquist ,LAIRD Nelco...)etc.Surface Treatment: HASL,ENIG,ENEPIG,Immersion Silver,Immersion Tin,Flash Gold,Golden Finger,OSP,Lead free HASL etc.HuanYu Future provides consigned assembly services for electronics manufacturers in small volume NPI format. We have procured seven lines of extremely high end SMT chipshooters, and with our own advanced management system, we build high quality, small to medium lot multispecies high value electronic products. We drastically cut cycle time to earn our customers first position at market share!Our engineering team has extensive experience in DFM/DFA/DFT technologies. SMT, BGA Rework, Re-balling, X-Ray are all readily achieveable. Stencils can be cut and delivered inside of 4 hours.Technical capacity SMT Position accuracy:20 umComponents size:0.4×0.2mm(01005) —130×79mm,Flip-CHIP,QFP,BGA,POPMax. component height::25mmMax. PCB size:680×500mmMin. PCB size:no limitedPCB thickness:0.3 to 6mmPCB weight:3KGWave-Solder Max. PCB width:450mmMin. PCB width: no limitedComponent height:Top 120mm/Bot 15mmSweat-Solder Metal type :part, whole, inlay, sidestep Metal material:Copper , Aluminum Surface Finish:plating Au, plating sliver , plating Sn Air bladder rate:less than20% Press-fit Press range:0-50KN Max. PCB size:800X600mm Testing ICT,Probe flying,burn-in,function test,temperature cycling Best RegardsHuanYu Future Printed Circuit Board Technologies Co., Ltd.MCPCB Aluminum PCB Flex Manufacturer Prototype huanyupcb.comPCB Manufacturer in china PCB Fabrication Express PCB PCB Suppliers Flex PCB Aluminium pcb PCB Quote Quick Turn PCB Prototype High-power LED PCB circuit board Double-Sided PCB Single-Sided PCB
