DHD NTX-3105
Heres a couple of pics let me know if you need more
The problem may be farther back in the circuit. Did you check the transistor to determine if it was defective?
If it's not defective, you'll have to follow the circuit back from the base of QP6 to see what drives it.
While you have it out of the circuit, reinstall QM1 to see if both channels will produce clean audio.
