Hi! I'm trying to develop DAC+Amp for PC. There are PCBs for power, DAC and amplifier in my project. Should I separate digital and analog ground in power PCB or do it in DAC/Amp PCB? Is there necessary to separate digital ground from transformer also? What should to use for separating - ferrite bead or ferrite ring and why?
Don't separate will be easy way, but right way is use ferrite for isolating AGND from digital stray
Nope, right way is a common ground plane in this application.
AGND & DGND refer to the separation ON THE CHIP to reduce common impedance coupling due to bond wire inductance, they should connect to the same plane on the PCB.
Regards, Dan.
Regards, Dan.
Is it, look at the information out there, especially from the likes of Henry Ott, plus numerous app notes from various IC manufacturers.
Separate the circuitry on the PCB and follow the various layout recommendations for mixed signal designs, most that say don't split your AGND/DGND.
Did you mean separation is already done in the chip or AGND and DGND should split near chip pins?AGND & DGND refer to the separation ON THE CHIP
The lowest impedance signal return path is the same as signal main path or the shortest path?
Use one ground plane...don't split them.
What chip are you using?
Current return paths...
http://www.x2y.com/filters/TechDay0...log_Designs_Demand_GoodPCBLayouts _JohnWu.pdf
Visible Return Current
Design News - Features - How Current Return Paths Affect Signal Integrity
Hi! I use DIR9001 (receiver) + PCM1794 (DAC).
I done PCB using solid ground plane:
(bottom side)
Should I partially split ground on the top side like this?
Are any other advices?
Thanks for your help!
(bottom side)
A signal must NEVER cross over a split in a ground plane.
The higher the frequency of the signal the worse the problem gets.
All the in/outs must be located close together at one edge of the PCB.
Are any benefit to place analog and digital in/outs together?All the in/outs must be located close together at one edge of the PCB.
I would need to read Ott again.
But one thing I do know:
I do not know enough to design a planed PCB.
The key things to remember is to always try to minimise current loop areas, especially when fast signals are concerned.
Lay the board out as if you were doing a split plane, but don't actually split the plane is generally best practise for most things.
I would critique that board as trying to be overly pretty (especially with those long curved tracks leading to vias to the ground plane), a via right next to the pad is almost always better then one 10mm of skinny trace away.
Get some decoupler ceramics right at the pins, and where possible connect them to the relevant pins without involving a via (Going say from a part on layer 1 -> via to ground -> via to layer 1 > decoupling cap ground end is much worse then part on layer 1 -> decoupling cap for all that both nets have the same names).
Quite often you will find that a sensitive part is designed to allow a 0603 or similar cap to be conviniently placed with the power and ground pins in reasonably good alignment, take advantage.
Those enormous thru hole caps are mostly a wate of time for HF decoupling, a 100nF or so X7R 0603 or even 0805 or 1206 will stomp all over them in effectiveness simply due to smaller loop area and hence less inductance.
the advantage of placing all the IO on the same edge of the board is that everything has the same ground and is thus less likely to radiate once the cables get outside the case.
I worry about the missing reconstruction filter parts, without it you still have significant energy up into the RF on those analogue outputs just begging to get into things.
Regards, Dan.
Regards, Dan.
Here next revision
Investigate this now=)I worry about the missing reconstruction filter parts, without it you still have significant energy up into the RF on those analogue outputs just begging to get into things.
Can anybody link reconstruction filters article? How its work, how to design filter, examples etc. Thanks a lot.
Are anybody can tell where I can find literature about reconstruction filter: how to design it, where is it used in DAC, etc ? Please! I was unable to find literature in Internet 🙁
quick answer I believe it is a low pass filter to get rid of the hf noise and conversion steps...search this forum there are threads on these filters.
I thought that low pass filter used for cut the signal to frequency range that subwoofer can play. And reconstruction filter used to make the signal smooth (as I understand DAC IC has output signal look like a stair).
Is it right?
Is it right?
Same thing, the steps are caused by the high frequency content of the output, filter that out and your left with the audio spectrum. There are others that can discuss this in more detail than I can, but that is the basics of a reconstruction filter.
- Power Supplies
- DGND AGND on PCB
