DENON DL-103SL Special Ceramic Moving Coil Turntable AT-MS11 Head Shell $400 inc shipping CONUS
This is a special cartridge. It was produced in 1989 with a white ceramic body for a more rigid body and faster response. It takes the already great sound of the legendary DL-103SL and takes it to the extreme. It also uses a 99.9999% high purity copper wire to reduce distortion.
EXC Condition
Cartridge SpecificationsModel: MC type
Output voltage: 0.25mV
Playback frequency: 20Hz to 45,000Hz
Electrical impedance: 14Ω
Proper stylus pressure: 2.5±0.3g
Dynamic compliance: 5×10-6cm/dyne (100Hz)
Weight: 9.7g
Needle tip: 6.5 micron round needle (0.2 mm square solid diamond)
Left and right separation: 25dB or more
Left and right sensitivity difference: within 1.5dB
Load resistance: 100Ω or more
EXC Condition
Weight: 9.7g
