Denon 103R needs help.
I was using a Shure V15VxMR before. My new toy 103R arrivved today but after I installed it in my turntable, audiable hum started. I cannot hear hum from my Shure V15 before unless I turn the gain of my preamp to over 80 (92 max) but now I can hear it at 60. I did try the following ways: -
1. Reduce the gain of the phono stage from 35db to 30db
2. Change the impedence from 100 ohmes to 82 ohmes
3. Unplugged the TT's ground cable
4. Un-ground the phono stage
5. Tried to maintain 47K impedence and at the gain stage of MM cartridge but I can still hear hum at 60.
My phono stage is ASR Mini-Basis. It is quite obvious that hum is genereated after connecting the tonearm wires and cartridge pins.
Help is needed. Thanks
Denon is MC and Shure is MM. If you corrected the gain setting of your phono preamp (it should be higher for MC) the problem could be related to the grounding & shielding. ASR preamps have plexy enclosures so perhaps the shielding is not perfect. Also, because of higher gain setting all the hum&noise collected through the wires are amplified in the phonopre.
Unconnect turntable from the phono preamp and check the hum. If it's gone than you're picking hum via cartridge or tonarm to phonopre cables.
If there is hum although the turntable is unconnected try to move phonopre and find if there is place where it doesn't hum.
Thank you for all the advices. I went through each and every advice and finally discovered that the hum is from the ASR. I'll try to shield the entire unit and see what will happen. But it is sad to see such a good preamp is picking up so much hum.:bawling:
