DD DM1500a *no switching after P.Supply & O.put failures
DD DM1500a, randomly blown power supply and output FETs, was told own hooked up subs wrong?
I removed all P.Supply and O.Put FETs, no switching on the tl494c or the lm393, I remove both to see what empty pads are getting/giving and it’s flat lines everywhere but 12.6v where it should be for each to function pins 8, 11, 12 on 494 and pin8 on 393 but 7.5v on pin 3 of 393), amp boots up blue light ok idling at .03a, I tried installing a known good lm393 to see if that does anything anywhere and it changes nothing. 494 gets no triangle wave/gives no waves, same as 393 regardless if good ICs installed for each or not.
Nothing else is probing bad with my DMM, except Q20, Q22 & Q28, Q30 are reading shorted between legs 1&3 with probes one way, same on each of the 4, but not when I reverse probes, so I’m assuming amp is designed as such and they are not actually shorted.
Currently reading up on the tl494 to see what it needs to operate, I know they have 2 comparators that need to run right to function (pins 1&2 + 15&16) and i am assuming the 393 is part of that and needa to function correcrly first before the 494 starts operating as it should.
Seems i have the hardest time with DDs for some reason, although the last i worked on had a bad PIC 😅 Any help greatly appreciated, i finally just got a new GPU and am in the process of rigging back up my watercooled gaming rig, almost ready for that guide, i have never wanted learning material this bad before ...lol
My apologizes for the late reply.
So the output FETs were heating up without me knowing (I still need a thermal camera and when I did feel them they did not even feel warm) when something went wrong and switching stopped on the output side that’s when I felt them and they were blistering hot :/
needless to say I have new OutPuts and Drive chips coming soon and will report back once I do.
thank you 🙏🏻
