Recently I have tried to build a digital out board based on the Tanto's project in DCX2496 mod for Digital OUT x 3 in 06-18-2004 07:16 PM. I am unable to obtained CS8404 in the market, I have replaced in with CS8405 and conenction as per his advice. I have also follow excatly the advice on all pins conenction, but I only manage to obtain output of 0.5 V peak to peak signal, can someone give some advice how should I troubleshoot from here.
Thanks.
Thanks.
Isn't that pretty much what the level should be for S/PDIF?
Edit: http://sound.westhost.com/project85.htm
