Facing a problem in ltspice.
When i try to increase power limit of an amp in ltspice for example +-35 to +-50 the out bias current and dc offset reduces. Is that normal? Instead of dc offset and bias should increase when power is increased.
You need to look into individual node voltages and collector currents to see what the causal relationships are. The power of Spice is that you have a lot more meters available, simultaneously, than you have on the test bench. Use them.
Thanks for explanation.You need to look into individual node voltages and collector currents to see what the causal relationships are. The power of Spice is that you have a lot more meters available, simultaneously, than you have on the test bench. Use them.
