Dayton PA465S x 2 vs single B&C 18TBW100
Hello, i was between Buying a Single TBW100 vs 2 RBX100,
But then i saw, the Dayton currently at $120.
I will run them for outdoors, Dj use.
On a Reflex box, 7cu after port. Box is tuned to 38hz.
I will run them with a Inuke 6000.
Currently running a single JBL 2241h 8ohm, but is not loud enough.
Im thinking of buying 2 Dayton PA465S and if that is not loud enough
then buying 2 more.
Or Should i brake the bank and buy 2 TBW100s?
B&C makes a better driver....but the Dayton is a killer deal and good driver as well. I would buy four right off the bat if you could swing it. Outdoors is tough on speakers.
Four off of that amp will be a big improvement and serve you well for a long time.
Yes the B&Cs are much better drivers but unless you put them in tapped horns(is that an option?) you may as well buy 4 of the Daytons. 2 TBWs in tapped horns would equal or exceed the output of 4 reflex PA465s and be roughly the same size.
According to the specifications the b&c and Dayton have roughly the same amount of xmax. If it's linear excursion that is limiting you and the cabinet alignments are very similar then the b&c is unlikely to give you much more than the Dayton.
