i'm crazy yo find in europe these two items from dayton :
binding posts
Dayton Audio BPP-SN Premium Binding Post Pair Satin Nickel - Binding Posts & Plates - Speaker Cabinet Accessories - Loudspeaker Components
binding plates
Dayton Audio SBPP-SI Binding Post Plate Silver Anodized - Binding Posts & Plates - Speaker Cabinet Accessories - Loudspeaker Components
please no : intertechnik
binding posts
binding plates
Hello diypass,
no I never bought from them before, but I can't see why not to be sure. I bought several times from europeaudio, which is also a dutch based shop, without any problems.
You should give it a try.
I also like very much the Dayton binding posts.
Good luck!
Good luck!
thank you gorazva, really for your suggestion, now finally i see the way.
i'll buy them next week.
dayton binding posts are equal to wbt ar fraction of price : if you see them you can see it.
dayton binding post have great value money.
thank you again for your site suggestion.
Equal how? Most WBT posts are copper based, meanwhile Dayton are brass.
Hello!
I do have 2 Dayton black binding plates. Here are details:Dayton Audio SBPP-BK Binding Post Plate Black Anodized 091-602
It IS possible to simply buy Copper Bolts (marine supply) for a happily small price and use those as Binding posts.
Not Audio Weenie approved ..But otherwise 'good enough ' 🙂
Dayton Binding ...
I like Dayton Audio products, and I like their binding posts for two particular reasons. First, they are only about 8 bucks, fairly reasonable. Second, (if they are the ones I remember) they are 'individually' mounted. This is very important, as I shorted and amp channel once using posts that were too close together. I think it's safer to have them WAY apart - like two inches!
Only one minor gripe about these posts .. It looks like the thumb wheel can spin all the way off - and could get lost if the speakers are unhooked and stored.
But this is minor, and if careful, you tighten them down always.
JT
JT
Nope. I just checked my both insulated and uninsulated Dayton Premium posts, and they do not free-wheel off the end of the shaft.
The older $9 posts you are likely speaking of have the knurled shaft and mount in a 0.25" hole. Those I believe do free-wheel off the end.
Later,
Wolf
Later,
Wolf
- Dayton binding posts and binding plate
