datzeel amp schema this work?
This amp is claimed to be VERY good if you believe reviewers. Considering the price, you may have trouble finding one to listen to in person. I have heard most of the ridiculously priced amps, but not this one. The schematic is simple enough. Build one and try it. I suspect it will sound quite good.
in a similar circuit
i was working with ...in a similar topology R13-14 was the sonic killers but also keep the amp working safelly .....
i could built it too ..... but on the other hand i dont like amps that have no trimers on them ....... there is nothing to adjust on them .... ha ha ha
then again 50 volt rails looks kinda much for only a couple of transistors
what happens in 4 ohms .... can these two transistors handle it ????
i think not .... well lets see ...
another thing i dont recall seeing somewhere else is the diodes in parallel with the base resistors ( D3-D4) ..... can somebody what is the exact purpus of that ????
thanks
regards sakis
Isn't this just a current feedback amplifier with a diamond buffer outside the loop as output stage? No emitter resistors, neiter in the input nor the output stage. I wonder at what bias it runs.
I guess it'll sound like a le Classe A.
