I have recently updated my iMac (M1 chip, SSD) and run Parallels Desktop for work, and all sorts of Window 11 software, including VituixCad, all good, and iMac runs both Op Systems simultaneously. So, I ordered the DATS V3 system.
While the software loads properly, it does not recognize the box connection (nor keyboard inputs) even though I have set input and output to its (USB via lightning bolt converter) USB Audio Codec connection, per the directions. Parallels states its because the software has not been upgraded to ARM architecture?
Ed P, over at Midwest Audio Club suggested I contact you on this forum.
Is there something I can set / do differently to get the measuring box to communicate through the connection?
If not, can the DATS V3 measuring box work with REW which runs directly on my iMac’s operating system?
Thanks in advance.
Andy
Thanks in advance.
Andy
Good morning. I have been trying to get a hold of John for a long time now?🤔. I have e mailed and left message’s? I wish I had a answer for you? Bummer I bought the dats Version 3. Now am trading for some gear. You could try posting this on the P.E. Tech forum?), Parts express? You might get a more up to date answer about John? Good Luck.
I did a writeup a while back on how I run a DATS v3 natively on MacOS using REW: https://www.diyaudio.com/community/threads/running-datsv3-natively-on-macos-using-rew.381943/
